Bent the forward HS spar reinforcement angles to 6 degrees per plan call out. Located the reinforcement angles on the forward spar and marked the bend line. Used a wood block to make the bend for the forward HS spar to correspond to the reinforcement angles. Clecoed the forward spare and reinforcement angles and to complete match drilling all holes in common.
