Brief Description: New HS Build Fwd Reinforcement Angles
Resumed building the new HS, started by clecoe, then match drilling the forward HS spar and reinforcement angles, then marked for the correct taper and diameter call out, then used a Dremel cut off wheel to remove most of the excess angle material, then used a file to remove the remaining material for both the upper and lower angles.
