My RV-8 Build Log
Date:  5-18-2018
Brief Description:  Spinner Gap Filler Attachment
Marked and drilled four equally spaced #40 holes in the gap fillers for use as a drill guide to locate the same on the aft bulkhead. Clamped the gap fillers in place on the bulkhead and match drilled. Final match drilled to #30 the gap fillers to the bulkhead.
Removed the gap fillers, machined countersunk the #30 holes in common with the gap fillers and the spinner supports. Deburred the gap fillers, spinner supports and bulkhead.
Ready for priming, then riveting.
Locating and Drilling RIvet Holes
Gap Fillers and Supports
Fitted for Riveting
Fitted for Riveting
