Brief Description: Spinner Gap Filler Final Trimming and Bending
After test fitting the spinner support to the gap filler, trimmed off the excess on the spinner support. Used a roller bend to bend the gap fillers to a shape compatible with the rear bulkhead.
• Test fitted the gap fillers to the rear bulkhead. • Identified some clearance issues with the spinner and marked the areas on the spinner. • Removed the spinner, and lightly sanded. • Refitted the spinner to check for the desired clearance.
