We need a minimum 1/8" clearance between the prop blade and the spinner because, well, this is going to move. For now, just trying to get the clearance with the prop in the flat position. Basically, the process is fit the spinner, take a look-see, determine where more spinner material needs removing, then mark conservatively, remove and sand off until I get to the trim line, and repeat.
