Brief Description: Spinner / Prop Cut Out and Fitting
After completing the initial cut-out of the spinner for the prop blades, used a router-style bit attached to a right-angle air tool to carefully remove the jagged edges and create an opening that fits around the prop. This required several iterations to ensure I did not remove more material than necessary.
