My RV-8 Build Log
RV-8
Air Inlet Finishing
Used a mixture of epoxy, hardener and microballoons to fill the holes left by the clecoes, and some extra to smooth the air inlet ramp transition from the top cowl to the ramp, and also where the ramp is affixed to the interior of the top cowl.
Right Air Inlet Ramp
Left Air Inlet Ramp
a bit of filler for smoothing air flow
RV-8 Home
2687
Ailerons and Flaps
Baggage Door
Brake System
Cabin
Cowl
DAR Inspection
275
342
322
Fairings
54
153
First Flight
Flight Control
Flight Training
Instrument Panel
Lighting
Markings, Placards a
Paint and Prep
Phase I
Pitot/AOA
Post DAR Inspection
QB Kit
Static Pressure Syst
Tech Councilor Visit
Tech Inspection
Tires
Transition Training
Weight and Balance
Windscreen
