My RV-8 Build Log
RV-8
GPS20A Test Fitting, etc.
Received the GPS20A for the GPS position source needed for ADS-B and 2020 compliance. Test fitted with the recently fabricated bracket, added a doubler plate to the top side to provide a bit more stiffness. Test fitted the unit on the bracket.
GPS20A WAAS GPS Source for ADS-B Out
Adding Doubler to GPS20A Bracket
Testing Fitting GPS20A to Bracket
RV-8 Home
2687
Ailerons and Flaps
Baggage Door
Brake System
Cabin
Cowl
DAR Inspection
275
342
322
Fairings
54
153
First Flight
Flight Control
Flight Training
Instrument Panel
Lighting
Markings, Placards a
Paint and Prep
Phase I
Pitot/AOA
Post DAR Inspection
QB Kit
Static Pressure Syst
Tech Councilor Visit
Tech Inspection
Tires
Transition Training
Weight and Balance
Windscreen
