My RV-8 Build Log
Date:  1-28-2018
Number of Hours:  4.00
Brief Description:  GPS Antenna Bracket
I decided to use a previously created antenna bracket for the GA35 antenna required for the GPS20A. The bracket uses WDG clamps to the top of the engine mount, and then AN bolts through the firewall, to provide a flat surface for mounting the antenna.
Using the antenna dimensions, created a cut out to make sure the mount position of the bracket plus the antenna clears the top cowl.
Bracket for GPS GA35 Antenna
Fitting of Antenna Bracket
Mock up of GA35 GPS Antenna on Bracket
