My RV-8 Build Log
RV-8
HS Fairing End Fill and Sand
Filled and Sand the HS End Cap Fairings where they face the elevator leading counter balance weights. Stowed the HS so the ends face upwards to keep the epoxy/microballons mixture from running all over the wrong places.
Fill and Sand the HS Fairing End
The start of several iterations
HS Stowed off of bench
RV-8 Home
2687
Ailerons and Flaps
Baggage Door
Brake System
Cabin
Cowl
DAR Inspection
275
342
322
Fairings
54
153
First Flight
Flight Control
Flight Training
Instrument Panel
Lighting
Markings, Placards a
Paint and Prep
Phase I
Pitot/AOA
Post DAR Inspection
QB Kit
Static Pressure Syst
Tech Councilor Visit
Tech Inspection
Tires
Transition Training
Weight and Balance
Windscreen
