My RV-8 Build Log
Date: 10-31-2017
Number of Hours: 2.00
Brief Description: Panel Fan, Switch and Circuit Breaker
While getting rid of some old computers (as in over ten), I disassembled the computers to destroy the hard drives, and recovered several fans. I found the best one, certainly the quietest and draws the least amps, to use as a panel fan. Carefully marked and cut a hole in the top of the panel for the fan, located the attachment holes for the flush screws, and installed the fan. The fan pulls less than one amp, used a 2A breaker and switch, and placed next to the panel dimmer. Relocated the panel dimmer to the left, and now have a panel control area, left to right, the panel dimmer, breaker for the fan, and the fan switch.
Adding Panel Fan Switch and CB
Avionics Panel Dimmer, CB and Switch
Panel Fan Installed
