I have a custom 9 pin D-Sub connector on the outside of the right fuse where the GSA28 roll servo is connected, this is where I am pulling the CAN BUS for the G5 (and anything else that gets added later. I pulled the shielded wire back through the fuse into the avionics bay and prepped for a new CAN Bus connection for the HI and LOW pins, and then added a new run replacing the existing back out to the right-side fuse for the 9-pin d-sub connector for the GSA28 Roll Servo. This was an easy process so plan on making this the ‘standard’ source when I need to add anything more to the CAN BUS.
