Drilled the HS for the platenuts required to attach the fairing in common with the HS and VS, countersunk skin for AN426 flush rivets. The empennage upper fairing has a platenut to be riveted to the skin interior side for the attach screw. The lower fairing is an aluminum strip, and will have a dimpled platenut, where as the upper platenut is flush mount since the fiberglass fairing is countersunk.
HS on bench, platenut holes drilled for VS/HA Fairing
