A lot of small things to do with the empennage at this point. Used a mixture of epoxy and microballons to fill the gaps between the elevator fairing and skin, let set up and started sanding. Removed the VS and Rudder, the VS needs holes drilled for plate nuts used to attach the fairing for the VS in common with the HS. Holes drilled for plate nuts, then countersunk for flush rivets.
