Removed the empennage to finish the fiberglass end caps and leading edge of the elevators. There's not much guidance on exactly what to do here, I plan on using a fill of epoxy and microballons to smooth the transition of the fiberglass fairings to the aluminum skin, as well as the elevator counterbalance weights on the leading edges. This should be interesting ...
