My RV-8 Build Log
RV-8
Intersection Fairings - Transition WIP
Proceeded with sanding the transition of the intersection fairing and the wheel pant. The idea is not to make it perfectly curved, but perfectly smooth. Several hours of sanding with a sanding block and other made up on the fly tools.
Sanding the intersection fairing transition
More sanding
more sanding
RV-8 Home
2687
Ailerons and Flaps
Baggage Door
Brake System
Cabin
Cowl
DAR Inspection
275
342
322
Fairings
54
153
First Flight
Flight Control
Flight Training
Instrument Panel
Lighting
Markings, Placards a
Paint and Prep
Phase I
Pitot/AOA
Post DAR Inspection
QB Kit
Static Pressure Syst
Tech Councilor Visit
Tech Inspection
Tires
Transition Training
Weight and Balance
Windscreen
