Removed the interference area on the front wheel pant fairing for the tire., combination of a Dremel cut off wheel and sanding wheel. Reassembled the pant on the left gear, re-aligned the pant front to back, and level-wise, re-verified with the right wheel pant fairing to make sure it is aligned the same.
Located the holes in the U-807 inboard bracket, matched drilled the fairing to the bracket to fix the alignment.
