My RV-8 Build Log
RV-8
Wings Back Off for More Work !
Matched drilled the fuel tank attach bracket for the AN bolt in common with the fuse tank attach bracket. Removed the wings... Using my platenut jig, drilled for the platenut attachments to the inboard right wing.
Fuel Tank Attach Bracket Drilled
Fuse Tank attach Bracket to Fuse
Platenuts riveted to inboard wing for fairings
RV-8 Home
2687
Ailerons and Flaps
Baggage Door
Brake System
Cabin
Cowl
DAR Inspection
275
342
322
Fairings
54
153
First Flight
Flight Control
Flight Training
Instrument Panel
Lighting
Markings, Placards a
Paint and Prep
Phase I
Pitot/AOA
Post DAR Inspection
QB Kit
Static Pressure Syst
Tech Councilor Visit
Tech Inspection
Tires
Transition Training
Weight and Balance
Windscreen
