My RV-8 Build Log
RV-8
Wing Tank Attach Brackets and Fairing Work
Aligned and match drilled the underside wing to fuse fairings with existing holes in wing. Finished off the fuse wing tank attach brackets, primed with SEM.
Match Drillng Wing to Fus Fairing
Wing to Fuse Fairing (Underside)
Wing Fuel Tank Attach Brackets
RV-8 Home
2687
Ailerons and Flaps
Baggage Door
Brake System
Cabin
Cowl
DAR Inspection
275
342
322
Fairings
54
153
First Flight
Flight Control
Flight Training
Instrument Panel
Lighting
Markings, Placards a
Paint and Prep
Phase I
Pitot/AOA
Post DAR Inspection
QB Kit
Static Pressure Syst
Tech Councilor Visit
Tech Inspection
Tires
Transition Training
Weight and Balance
Windscreen
