My RV-8 Build Log
Date:  7-5-2017
Brief Description:  Wing Tip Fairings and Lens
Started working on the wing tip fairings, and since I just finished working on the Sun Tail light in the rudder, decided to work on the lighting and lens. The lens is one piece item from Vans, so I cut in half, and place each half on its wing tip. Traced the contact line where the lens will be secured. I used snips to cut the lens, and various grit sand paper glued to wood blocks to sand the edges for the initial fit.
Initial Lenses on wing tip fairings
Trace Line for initial cuts
Ffitting after initial cut
