Wired the Molex connectors for the Nav, Strobe, Land and Recognition lights, ran wiring through wing ribs. Also, ran wiring for the GMU 22 just in case I have to relocate it from it's current position in the mid-fuse to the right wing tip if it will not pass the interference test.
Molex for Land/Rec and Nav/Strobe
Had to remove Roll Servo to run the wiring
Right Wing Nav/Strobe, Land/Rec, Roll Servo and GMU 22
