My RV-8 Build Log
RV-8
Rudder Light Wire Routing
Routes the Sun Tail wire down the VS into the rudder fairing, and secure using cushion clamps to keep from rubbing on the rudder. Per Aeroleds instruction for the Sun Tail, the light is grounded as close as possible to structure. This may change ...
Aeroled Sun Tail grounding per spec
Molex plug for Sun Tail
Wiring Routing from Rudder Fairing
RV-8 Home
2687
Ailerons and Flaps
Baggage Door
Brake System
Cabin
Cowl
DAR Inspection
275
342
322
Fairings
54
153
First Flight
Flight Control
Flight Training
Instrument Panel
Lighting
Markings, Placards a
Paint and Prep
Phase I
Pitot/AOA
Post DAR Inspection
QB Kit
Static Pressure Syst
Tech Councilor Visit
Tech Inspection
Tires
Transition Training
Weight and Balance
Windscreen
