Brief Description: Right Wing Tip Fairing Bottom Platenut Strip
Removed the right wing tip fairing from the wing after final sizing the holes for the #6 screws. Trimmed aluminum strips about 1" width to attach to the underside of the wing tip fairing in common with the plate nuts. Matched drilled the strip to the fairing, the strip will provide a bit more structure for holding the shop side of the AN426-3 rivets used for the K1000-6 platenuts.
