Proceeded with fitting the right wing tip to the right outboard wing. Slid the fairing into the space allocated inside the right outboard wing, pushing down from the trailing end to get a tight fit. Use a side clamp to hold the wing tip flush in place against the inside of the outboard wing.
matched drill #40 the pre-punched holes in the outboard wing to the wing tip fairing. Installed the wing tip rib inside of the fairing, located and matched drill #40 using the rivet fan to equal distant spacing.
RIght Wing Tip Flush to Wing
Locating and Match Drilling Holes for Wing Tip Rib
