The wing tip must be trimmed to clear the outboard aileron bracket on the wing. Mated the wing tip and marked the location of the initial trim. Remove the excess material with a Dremel style cut off wheel and air tool. The wing tip rib needs to be fitted in the aft portion of the wing tip, but before I can do this, the wing tip needs to sit flush with the outboard wing.
