In the process of attaching the right wing for the first time, I trimmed the fuel line existing the fuse too short. The easiest way to fix this was just to make a new line, using the old line as a template. Removed the old line, and measured to make the bends to the 3/8" tubing to make the new line, leaving sufficient tube where it exists the right-side fuse. I think this is the third iteration of this line.
