Brief Description: Roll Servo Wiring in Right Wing
Proceeded with running the wire and connector for the GSA28 roll servo in the right wing. The servo has been installed for some time, the wire has not. In the process of re-familiarizing the wire requirements, I realized the power wire for the server has not been run. I verified inspecting the 5-amp CB on the panel, there should be two wires for this CB, one for the pitch servo, the other for the roll server. Only the pitch servo had a power wire, so ran a wire to the roll servo.
