Brief Description: Started the Left Side Fuse for Flap Rod
Started working on the left side fuse for the flap rod. Made a template for the cut-out based on the right side using the rivet locations on both sides. Started by drilling some pilot holes then enlarging using a unibit, then a grinder attachment to my air grinder.
Made a lower rod end bearing spacer on the same dimensions as the right side for the flap rod. Attached the flap and placed painters tape around the fuse to mark any interference when attempting to raise, the tape marks the contact point.
Used a template made from the right side for the left
