Worked on getting the Right Flap Rod aligned to pass through the lower fuse and floor. Added spacer to the lower rod end bearing to get the flap rod aligned and to pass through the fuse and floor without contacting either. There is more worked to do here as the flap rod bearing clears both, and the flap skin needs trimming as it just misses the fuse
