Brief Description: Rod End Bearing to Flap Attachment
Made a tool for holding the nut required for the rod end bearing which attaches to the flap. There's very close clearance and dang near impossible the hold the nut in place while attaching the rod end bearing. Attached the top rod end bearing the flap weldment in the fuse while the weldment was in roughly the middle of travel.
It is apparent that opening the hole in the fuse is necessary to allow full up and down travel, just how much will be a process of cautious removal and testing, and testing and testing...
