My RV-8 Build Log
Date:  3-28-2017
Brief Description:  Right Aileron Neutral Position adjustments
Attached the aileron push / pull tube to the bell crank, Adjust the rod end bearing and checked the aileron for neutral position. Neutral position is determined by aligning the two tooling holes in the aileron to the tooling holes in the outboard wing rib forward of the main wing spar.
Aileron push/pull tube and rod end bearing
Tools for rod end bearing adjustment
Determining the Flap Neutral Position
