Bent the left flap inboard leading edge of the top skip 90 degrees as required to clear the rear wing spar and flap brace. Fitted both flaps to the wing and ensured they both will clear the fuse in the anticipated neutral position.
Both flap inboard skins just barely clear the fuse skin, I anticipate additional trimming is required.
