My RV-8 Build Log
RV-8
Right Flap Fitting to Fuse
Bent the inboard flap top skin leading edge the required 90 degrees to clear the aft wing spar and flap brace. After installing the right flap, determined more trimming is required of the flap top skin to clear the fuse.
Bending the Inboard flap leading edge
More trimming for the inboard top flap skin
Inboard Flap Top Skin Lead Edge Bent
RV-8 Home
2687
Ailerons and Flaps
Baggage Door
Brake System
Cabin
Cowl
DAR Inspection
275
342
322
Fairings
54
153
First Flight
Flight Control
Flight Training
Instrument Panel
Lighting
Markings, Placards a
Paint and Prep
Phase I
Pitot/AOA
Post DAR Inspection
QB Kit
Static Pressure Syst
Tech Councilor Visit
Tech Inspection
Tires
Transition Training
Weight and Balance
Windscreen
