My RV-8 Build Log
Date: 1-11-2017
Number of Hours: 2.00
Brief Description: GDU 460, IBBS Reinstallation
Finally got all the avionic components reinstalled in the panel after many months of storage while I worked on the front windscreen fairing. Moved on to the components located under the right-side console, the IBBS and ADS-B receiver. The connector for the IBBS was more difficult than anticipated, the alignment tabs are difficult to see, so attaching the connector required a lot of extra light, and a mirror to make sure it was aligned, otherwise just twisting the connector in the hope of landing on the right spot, just did not want to work.
Once connected, there's still a bit of wiggle in the connector, which seems undesirable, and I'm not too sure why this is, but is certainly connected the only way it will align to the battery.
GDU 460 ready to re-install
Finally togeter again after many months
IBBS Plus is being difficult
