My RV-8 Build Log
RV-8
Avionics Forward Bulkhead Stiffeners - II
Final drilled the #40 holes to #30 for the LP4-3 rivets I will use for the stiffeners.
Final Drilled for LP4-3 rivets
RV-8 Home
2687
Ailerons and Flaps
Baggage Door
Brake System
Cabin
Cowl
DAR Inspection
275
342
322
Fairings
54
153
First Flight
Flight Control
Flight Training
Instrument Panel
Lighting
Markings, Placards a
Paint and Prep
Phase I
Pitot/AOA
Post DAR Inspection
QB Kit
Static Pressure Syst
Tech Councilor Visit
Tech Inspection
Tires
Transition Training
Weight and Balance
Windscreen
