My RV-8 Build Log
Date:  11-18-2016
Number of Hours:  5.00
Brief Description:  Main Gear Leg Fairings
Decided to take a break from sanding the canopy and windshield fairing, and work on something different. Proceeded with trimming the main gear leg fairings per plans, and trimming the hinge used to hold the gear leg fairing together on the aft side of the fairing. The hinge is riveted to the inside of the fiberglass fairing, with the pin inserted from the bottom of the fairing (somehow)...
Gear Leg Fairing Hinges
Trimming the Gear Leg Fairing
Left Gear Leg Fairing Trial Fitting
