Brief Description: Front Windscreen - Rough Fitting
Finally started working on the front windscreen. It's been stored on a shelf in bubble wrap for years, but now is the time to determine how it needs to be trimmed. The original trim leaves the windscreen about one inch above the roll bar.
I know I really need to take my time on this process. Taped the lower edge where in common with the fuse top skin. The plan is to trim a small portion from the bottom edge by tracing the skin contour around the perimeter about 1/4".
