The left side console was missing a nutplate, because the rivets were either overdone or too short for the job. Drilled out the old rivets, not so easy since it it right up against the side skin. For the right side console, the nutplate was there, but somehow not aligned to the hole for the screw, so drilled this out as well.
I filled the rivet holes on both sides with J-B, will let it set 24 hours before I re-drilled the rivet holes, countersink an install new nutplate.
