Proceeded with locating the holes for the forward seat floor ramp support angles. These will attach to the top plate overlapping the forward spar, as well as the left and right console support brackets. There are three nut plates per side to locate and install. Instead of match drilling the holes using the assembled forward floor ramp., I just marked, then removed the floor and then drilled the #40 pilot holes.
