Brief Description: Fuel Line Grommet - Servo to Red Cube
Installed the grommet in the inter-cylinder baffle between cylinders 2 and 4 for the fuel line pass-through, and ran the fuel line through as needed, Secured the fuel line below the baffle and above the baffle using WDG clamps secured to custom brackets fabricated from left over steel attach brackets from the tail.
