Fabricated a bracket for attaching the fuel line where it passes between cylinder #2 and #4 from yet another spare vertical stab hinge. These are quite strong, so I am comfortable attaching a fuel line to these. Cut down a hinge to form the bracket, and drilled out for the Fuel Divider bracket bolt attach hole for the 1/4" required, then drilled a hole needed for an AN3 bolt to attach a WDG clamp.
The clamp ensures the fuel line does not contact the cylinder or rub in any way.
Last Pic is of the fabricated clamp under cylinder #2 which attaches the fuel line from the fuel servo through the inter cylinder baffle to the red cube, and on its way to the fuel divider.
Fuel Line Bracket Fabrication
Fuel Line Bracket attached to Fuel Divider Bolt with WDG Clamp for Fule Line
