Brief Description: Fuel, Oil and Prop Line Specifications
Now that the red cube is situation, I can complete the measurements for the fuel and oil lines needed for the FWF. I have a prop line from the original engine purchase which is too long to work, but I can use it to determine a line length that will work. This turns out to be 32" from the fitting on the front of the engine to the prop governor at the rear of the engine.
I want to use fire sleeved lines for the oil cooler in and out, so even though I have lines that fit, they are not fire sleeved. For all the lines needed, there are seven of them.
