Brief Description: Forward Top Cowl Air Seal - Inboard and Outboard
I am a little unsure how the forward top cowl air seal is going to make a good seal given there is no complimentary aluminum strip for the top, because there is no 'top' forward air ramp. I decided to add air seal material which will hopefully reach far enough forward to create a seal of sorts.
Basically, I am just attaching air seal material so the sides of the top cowl air inlet compress against the left and right side cylinder baffles.
For the inboard top cowl air seal material, I am attaching air seal material to the forward baffle which will be compressed by the top cowl when in place.
