Brief Description: Installing Oil Cooler and Lines
Had to make a 9/32" spacer for the inboard long bolt, this is to make sure the bolt does not contact the #4 cylinder when it passes through the nut place on the forward side of the aft oil cooler baffle. Installed the oil cooler with the required hardware. Installed the AN822-8D elbows with fuel lube, and installed the 1/2" oil cooler lines from the engine.
The return oil cooler line was too close to the wiring for the fuel pressure sensor, so a bit of adjusting fixed that issue.
