The front air inlets have air seal material from the bottom cowl to the forward ramps. Two air seal clamps are required to hold the air seal material in place. Used the vise and pliers to manually bend the clamps to conform to the bottom cowl. The bends are more complex than you might think as the curves are not symmetric and the clamp has to be bent forward as well as upward for a good fit.
