My RV-8 Build Log
RV-8
Baffle Riveting
Proceeded with riveting the main baffle components... after riveting, there will be four main baffles, the left aft is riveted to the cyl #4 baffle, the left front riveted to the cyl #2 baffle. same set up for the right side.
Left aft baffle riveting ...
Left Aft Baffle riveted to # 4 cyl baffle
Right aft baffle riveted to cyl #3 baffle
RV-8 Home
2687
Ailerons and Flaps
Baggage Door
Brake System
Cabin
Cowl
DAR Inspection
275
342
322
Fairings
54
153
First Flight
Flight Control
Flight Training
Instrument Panel
Lighting
Markings, Placards a
Paint and Prep
Phase I
Pitot/AOA
Post DAR Inspection
QB Kit
Static Pressure Syst
Tech Councilor Visit
Tech Inspection
Tires
Transition Training
Weight and Balance
Windscreen
