My RV-8 Build Log
Date:  5-26-2016
Brief Description:  Conical Gussets for front engine baffle
Located and matched drilled #30 holes for the left and right conical gussets which server as cone shaped connector between the ramps and cylinder baffles. Deburred, then riveted. I found the best way to rivet these was in place on the aircraft using bucking bar and rivet gun.
Left Conical Gusset
Left Conical Gusset
Right Conical Gusset
Prepped for Riveting
