Brief Description: Front Baffle Assy Continues.,..
Continued with the assembly of the left and right front ramps. Located, drilled, deburred, then riveted as required the brackets in common with the front baffles, clecoes to the left and right ramp baffles. These were a bit challenging to rivet since the parts are not amenable to significant clamping due to their odd shape. Used a combination of squeeze and buck as needed.
Rivet the brackets in common with the left ramp
Left front bracket and brackets clecoed to left ramp
