Despite know this could happen, my effort to prevent having an issue with locating the Camloc holes for the Camloc tabs nearest the cylinder covers where no direct lighting is possible, I miss-centered several holes.
The fix is easy...
User a Dremel to increase the hole to change the center as needed to align with the Camloc receptacle. Located the Camloc retainers, and fitted the Camloc screws. Used tape to hold the Camloc retainers in place.
I will repair the fiberglass epoxy from the reverse side to close the gap where needed
