Continued fitting the top and bottom cowl halves together. This operation is tricky because each action to trim something can result in a problem elsewhere. Using cargo straps overlapped the top cowl with the bottom cowl and marked a line for continued trimming. Trimmed using #60 grit and a sanding block, lots of sanding....
